Author Topic: Cruise control  (Read 3810 times)
Offline Mk6woody
Cruise control
« on: 24 May 2013, 12:00 »
Hello!
New to this forum guys so go easy ;)
I'm interested in retrofitting cruise control to my mk6 2012 golf
Can any one shed some light on what's involved?
I've had a search about and found lots of info on the earlier mk6 where it's a case of replacing the stalk and coding via vagcom is it something similar for the later mk6?
Thanks in advance
James
Offline dubber36
Re: Cruise control
« Reply #1 on: 24 May 2013, 12:06 »
Awesome GTI in Manchester will do it. It's £299 on there web site. I'm not sure why it is so expensive as they only charge £120 for older cars like Mk4 Golfs.
Offline Mk6woody
Re: Cruise control
« Reply #2 on: 24 May 2013, 12:28 »
Thanks for the reply,
I had seen that from awesome GTi I don't understand the price diferance,
I was hoping to do it myself if it was similar method to the mk4/5
James
Marshy
Re: Cruise control
« Reply #3 on: 24 May 2013, 13:04 »
I fitted to my 59 plate gtd.
Replaced the stalk and coded by vagcom and it works perfect.
I did read that its more involved on 2010 on cars but not sure why.
Offline Jimble
Re: Cruise control
« Reply #4 on: 24 May 2013, 13:31 »
It's more expensive on later mk6's as they replace both stalks, i assume it's all one unit but when i had mine retrofitted at the stealers it was only £170, mines a march 2010.
The steering wheels has to come off as does the couling, the stalks are replced and then coded.
Offline Mk6woody
Re: Cruise control
« Reply #5 on: 24 May 2013, 14:26 »
Thanks for the info I'll try the dealer see what they say :)
Offline TomS_
Re: Cruise control
« Reply #6 on: 24 May 2013, 18:25 »
My dealer quoted me £85 for the replacement stalk (singular, at least there was no mention of a plural, unless both stalks are part of a single unit), and £180 for labour.
I queried them on whether there were any additional modules required as someone had mentioned that here, they said they spoke to their chief mechanic and it would just be the stalk. I assume theres also some coding needed as well.
« Last Edit: 24 May 2013, 18:27 by TomS_ »
Mk6 GTD, MY12, candy white
Offline Snoopy
  • Moderator
  • Geoff.
Re: Cruise control
« Reply #7 on: 24 May 2013, 20:27 »
was yours the older single stalk version then? Always ment to do mine.
Iirc later cars the stalks are all one and something like the slip ring also gets replaced.
I know I have asked this question before and the differences and what was needed were pointed out.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Mk6woody
Re: Cruise control
« Reply #8 on: 24 May 2013, 22:19 »
Been on to my dealer they can't quote me for this work :/
Don't really fancy paying out £300 for somthing that might be fairly straight forward.
Anyone know exactly what's needed
Ps thanks for the replys
Offline Jimble
Re: Cruise control
« Reply #9 on: 25 May 2013, 00:17 »
Yeah mine only needed the indicator stalk changing, i was one of the lucky ones as it was cheaper than factory fit! :cool:
I think yours may have came over on the same boat so should be the same?
It's gonna cost you a few £££ unfortunately mate but you should be able to find a dealer to do it, i'm pretty sure it's still listed in the dealer fit accessories.
