Author Topic: 9.5j 18" wheels, will I need any work to make them fit?  (Read 8440 times)
Offline tom94
Just bought some 18" 8.5j front and 9.5j rear wheels with an offset of 35.
Just wondered if anyone has any experience of having wheels this size and whether any work needed doing.
I'm expecting a bit of work to need doing but not sure how much.
Any help is appreciated!
Offline dom
  • Back in a Mk4
Re: 9.5j 18" wheels, will I need any work to make them fit?
« Reply #1 on: 24 May 2013, 13:02 »
Should be fine as long as you're not silly low. What tyre size?
Offline Chris#101
« Reply #2 on: 24 May 2013, 13:17 »
IM running  the same spec as you 9.5j rear and 8.5j front both et35.
You'll need 15mm spacers on the rear to clear strut and 10mm spacer at the front
IM running 225/40/18s all round, it is a tight set up but does look sweet :cool:
 :smiley:
« Last Edit: 24 May 2013, 13:21 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline tom94
« Reply #3 on: 24 May 2013, 13:20 »
Ahhhh sweet! I'm 225/40/18 on the back and 215/40/18 on the front. Spacers will be bought then!
Offline Chris#101
« Reply #4 on: 24 May 2013, 13:22 »
Yer man I wanted as little stretch on front as possible due to the power it's got to lay down. The rear stretch is just right
Offline tom94
« Reply #5 on: 24 May 2013, 13:27 »
Sounds good!
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #6 on: 24 May 2013, 14:40 »
What does stretch have to do with the power?  :huh:
Offline dom
  • Back in a Mk4
« Reply #7 on: 24 May 2013, 16:16 »
Believe it or not, properly fitted, wider tyres are better at getting the power down than thinner stretched one's  :grin:
Offline scarr89
« Reply #8 on: 24 May 2013, 17:13 »
That would have been my initial thought... :huh:
Offline Chris#101
« Reply #9 on: 24 May 2013, 17:26 »
What Dom said.... Obviously the wider the tyre and surface area it covers on the road the more grip you have...  :huh: and aswell as putting the power down it also steers so the concern of it popping a bead/ tearing a sidewall out is increased, which is something I don't really want to experience !?
