Author Topic: mk4 1.8t broke down on the way to work this morning.  (Read 2351 times)
Offline thatwillis
Hi guys.
Driving my golf to work this morning I noticed it got a little lumpy then a min later the revs dropped and it cut out. It now won't start. I'm now at work so I cant check for codes. Would anyone have an idea off the top of their heads what it might be? It still turns over but wont take.
Much appreciated
Willis
jamie16v
Re: mk4 1.8t broke down on the way to work this morning.
« Reply #1 on: 24 May 2013, 11:53 »
ignition module?.
Offline thatwillis
« Reply #2 on: 24 May 2013, 12:12 »
ignition module?.
Any idea of the easiest way to test if thats the problem?
Offline Dalo Harkin
« Reply #3 on: 24 May 2013, 12:23 »
check the basics first, fuelling, spark etc
when you say turns over do you mean it just sounds like its cranking or does it fire up?
if just cranking then its most likely fuelling or ignition so plugs (ignition amp if it has one) etc
« Last Edit: 24 May 2013, 12:29 by Dalo Harkin »
Offline navmk4gti
« Reply #4 on: 24 May 2013, 12:29 »
What engine code is it. If agu i will say ignition amp too. But cant really know until u scan it mate :wink:
Offline asboGTI
« Reply #5 on: 24 May 2013, 13:05 »
looking at his sig can just about make out its a t reg so porbs an AGU
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline thatwillis
« Reply #6 on: 24 May 2013, 16:11 »
Thanks for your help. Yeah its an AGU. How easy is the ignition amp to change? Expensive part?
I'll scan it when I get back from work. Whats the code likely to say if it is the ignition amp?
jamie16v
« Reply #7 on: 24 May 2013, 16:23 »
it`s piss easy to change, its bolted to the side of your airbox with 2 10mm (iirc) bolts and two plugs clipped onto it.
not sure if a new one will come with heat transfer compound but you can get that from maplins cheaply..
Offline thatwillis
« Reply #8 on: 24 May 2013, 16:35 »
Thats what I like to hear. I'll get it home check to see if I get a spark if not ill get a new ignition amp. Thanks  :smiley:
Offline Nino
« Reply #9 on: 24 May 2013, 16:52 »
Could this not also be the coils?  :huh:
Current - MK6 GTi Edition 35
