Author Topic: Fitting rear bushes  (Read 972 times)
Offline SI74
Fitting rear bushes
« on: 24 May 2013, 07:46 »
Did this yesterday in about 15 mins couldn't believe how straight forward it was to do. I had already planed for it had got myself a few bits to do it with. I also gave the hole where the bush goes a good clean out with a sand paper wheel on the end of a drill.
2 19mm spanners
2 bits of metal plating
76 OD pipe
10 inch of M12 threaded bar
2 M12 nuts and washers
Then I made it up so it was just a matter truning the bolt and press in the bush.
Job done.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Fitting rear bushes
« Reply #1 on: 24 May 2013, 08:51 »
Much easier when off the car... :lipsrsealed:
Good like set up.  :smiley:
Offline mcgee9t2
« Reply #2 on: 24 May 2013, 09:24 »
yeah took me bloody ages on the car :D
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 24 May 2013, 10:01 »
I've witnessed several hours and much swearing fitting rear bushes without such a device.
The Laser fitting kits are like £70 for what they are!
Mk4 Golf 150PD
