Author Topic: mixture adaptation  (Read 2840 times)
Offline welshdean
mixture adaptation
« on: 23 May 2013, 19:33 »
Hi all,
I've just had my car 're-scanned today and was happy with the result. Recently I've experienced problems with feeling a judder through the accelerator pedal on take off. I've cleaned my throttle body and it has definately helped a lot. So like I've said above, I've had the car 're-scanned and happy with the outcome of just one fault code. But I'm confused as to what it means exactly.
The fault description is as follows.....
00561 - Mixture Adaptation
               14-00- Adaptation Limit (add) Exceeded
I've looked on the net and found a post mentioning something about throttle body alignment.   :laugh:
Offline navmk4gti
Re: mixture adaptation
« Reply #1 on: 23 May 2013, 19:58 »
Iv got this too and need clean throttle body too :grin: did you align yours back with vagcom? What engine code you got
Offline welshdean
« Reply #2 on: 23 May 2013, 20:35 »
My engine code is agu and I've already cleaned the throttle body and just erased the code. Or do you need to do something more than just erase it for everything to be ok
Offline navmk4gti
« Reply #3 on: 23 May 2013, 20:41 »
Nope agu is cable throttle so will settle itself after a few miles :grin:
Offline welshdean
« Reply #4 on: 23 May 2013, 21:04 »
Ok, well a throttle body clean can't be the cause of the code in that case as since I cleaned it, put it back, and drove it about 40 miles the fault would not be there when scanned today if it settles itself back. So it must be something else
Offline navmk4gti
« Reply #5 on: 23 May 2013, 21:13 »
You got any powerloss? How is your mpg? Could be maf.
Offline navmk4gti
« Reply #6 on: 23 May 2013, 21:17 »
Taken from rosstech..
00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
Possible Symptoms
Engine JoltingIncreased Fuel ConsumptionPoor Idling/JoltingReduced Boost Pressure
Possible Causes
Mass Air Flow Sensor (G70) faultyFuel Pressure too LowLeaks in Intake Air System and/or Exhaust SystemInjector(s) faulty (i.e. coked)
Possible Solutions
Refuel VehicleCheck Fuel System PressureCheck Mass Air Flow Sensor (G70)Check Intake Air System and Exhaust System for LeaksCheck Injection QuantityCheck Injector(s)
So seems like most likely maf mate. U luky to get fault code so atleast you can pin point it. Take maf off take it for a spin see how it feels  :wink:
Offline welshdean
« Reply #7 on: 23 May 2013, 21:18 »
As I'm new to the car I couldn't honestly say 100% that there is or isn't powerloss. However, I've not noticed any difference in the drive and mpg is averaging between 24-28mpg (urban)
Offline pickles
  • Next!!!
« Reply #8 on: 23 May 2013, 22:46 »
i had this for ages after decatting and fitting a new exhaust, changed MAF and Lambda sensor but was still getting it so i done a smoke test, ended up it was  a leak in the inlet manifold, maybe worth doing.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
