Cosmetic and bodywork matters
fitting body kits
Topic: fitting body kits (Read 2008 times)
Cadde GTI Turbo
Caddie MK4 1.8TURBO
fitting body kits
23 May 2013, 11:48 »
I had a garage fit the extension to my front bumper, looking how it's been fitted it looks like it has been glued in.
What do they use as I want to give fitting my rear extension ago?
wheelygood
Re: fitting body kits
23 May 2013, 16:33 »
tigerseal/sikaflex
Callum_K
Here all the time
12 June 2013, 13:31 »
Head to your nearest Toolzone, they do a Polyurethane adhesive called PU40, exactly the same as Tigerseal etc but about 1/3 the price.
Thom89
Forum addict
Looking for an "Icebreaker"
18 June 2013, 23:08 »
Do not use PU based products to bond body parts together, whether its "Tigerseal" or Sikaflex or whatever! These are adhesive sealers, and are meant to fill gaps in bodywork prior to paint...
Windscreen bonding adhesive is the correct product, and far easier to use! parts will stay attached to your car!
http://compare.ebay.co.uk/like/220785586445?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=63
Thom
fitting body kits
