The garage
mk3 1.8 8v black smoke
Topic: mk3 1.8 8v black smoke (Read 1667 times)
samgt1275
Just got here
21 May 2013, 18:26 »
Hi got a 96 1.8 single point driver with lack of power and puffing black smoke at full throttle.
All new on ignition side. has anyone had any faults with lambdas?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: mk3 1.8 8v black smoke
21 May 2013, 18:36 »
get fault codes read and measuring blocks analysed as well.
could be a number of things starting with a bad temp sender to faulty injector...
just guesswork in cases like these so get someone to look at it with vcds
samgt1275
Just got here
21 May 2013, 19:11 »
I live near poole and dont know anyone with the old vag diag plug.
Taking into work to check lambda values tomorrow but can just smell pure fuel coming out of exhaust
itavaltalainen
21 May 2013, 19:38 »
checking lambda value with exhaust tester won't test you why it's rich running.
check the vcds user map, am sure there's someone nearish.... there is a pretty well populated map on vwaudiforum.co.uk
Wayne
Sir Postalot
21 May 2013, 21:03 »
Coolant temp sender could be faulty and causing it to run rich.
The garage
