Author Topic: What's the score with....  (Read 4243 times)
Offline dom
  • Back in a Mk4
Re: What's the score with....
« Reply #10 on: 23 May 2013, 22:26 »
ET32 pokes more that ET35 so it would sit further away from the caliper.
Offline Nino
« Reply #11 on: 23 May 2013, 22:40 »
oh, I thought the fitment for mk4 golfs were ET35 for a perfect fit, so I wouln't have any problems with ET32 on the front then?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline dom
  • Back in a Mk4
« Reply #12 on: 23 May 2013, 23:23 »
Et32 will be fine, I'm running et15 and et20 with no problems. Personally I like the wheels flush with the arches so want a low offset.
Offline Nino
« Reply #13 on: 24 May 2013, 10:40 »
Cheers Dom
Offline dom
  • Back in a Mk4
« Reply #14 on: 24 May 2013, 13:05 »
Just for reference, 8J wheels with a final offset of ET15, coilovers all the way down with adjusters removed:
Offline Nino
« Reply #15 on: 24 May 2013, 21:23 »
Niiiiiiiiiiiice! Using spacers?
Offline Carl!
« Reply #16 on: 11 February 2014, 08:19 »
Dom is that on 215/40's?
im running 8j et35 with big spacers on rear, assuming they are 20mm if not bigger as I need to measure them which im going to do. trying to work out if 215 will sort out as 225's on at min or better swapping spacers, ive highered it up to about 50mm low but its still catching over bumps or when there is 3 in.
Offline GTi_James
« Reply #17 on: 11 February 2014, 12:06 »
you changing wheels again?!
Offline dom
  • Back in a Mk4
« Reply #18 on: 11 February 2014, 13:09 »
Yeah, that was 215/40/18 with a 20mm spacer, it sat pretty well but scrubbed with any weight in the rear.
Offline Nino
« Reply #19 on: 11 February 2014, 19:55 »
HAha no, my old thread been revived  :rolleyes:
