Author Topic: injector problem  (Read 2596 times)
Offline PATEMANUK
injector problem
« on: 20 May 2013, 20:43 »
hi guy i have a golf tdi 150 the other day the car started to run lumpy so put it on the vagcom and came back saying number 2 injector so i replaced with a recon one also changed the loom to the injectors but still have the same problem do you have to programe the recon injector the car ?? HELP
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: injector problem
« Reply #1 on: 21 May 2013, 00:22 »
I believe the injectors do have to be set up.
The seals can be quite awkward and cause issues if not correct iirc.
Offline EsSeX dAn
« Reply #2 on: 23 May 2013, 23:45 »
its not the chocolate camshaft syndrome starting to show itself is it?
i think i love you.....
