Author Topic: conlog removal guide  (Read 1191 times)
Offline mrsaunders
« on: 20 May 2013, 19:21 »
is there a guide to remove my alarm, i can get a new key and coded chip from vw for £50ish but still need to remove my alarm, help me please!   :embarrassed:
Offline Bellend
Re: conlog removal guide
« Reply #1 on: 20 May 2013, 20:03 »
Trace the wiring and join up wires basically.
There should be something cut for the fuel line say, wire cut then two wires joined to either end. Remove these and join and fuel pump should now be working.
Starter should be the same. Once it's running you can continue removing it correctly or do what everyone else does and just cut the power to the alarm box and leave it.
Where all my moneys went.
