Author Topic: bench testing a Mk4 cluster  (Read 3992 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 19 May 2013, 15:47 »
As above, anyone know what pins to connect to get it to work?
jamie16v
Re: bench testing a Mk4 cluster
« Reply #1 on: 19 May 2013, 20:49 »
http://www.golfgtiforum.co.uk/index.php?topic=98752.0
good old google... even better than the search function. :wink:
Here is the pin out for the cluster loom - big thanks to the clock guru Neil old_no7
MK4 Cluster Harness GREEN
1 - Open
2 - Reader coil for immobilizer 1
3 - Indicator lamp for parking light*
4 - CAN Data Bus, shielded input
5 - W-wire*
6 - Indicator lamp for low windshield washer fluid - Power to silence alarm
7 - Brake pad wear indicator - Earth to silence alarm
8 - 9 - Open
10 - Low fuel level warning
11 - Signal for vehicle stationary*
12 - A/C clutch cut-off - Engine Coolant Temperature (ECT) signal
13 - Warning lamp for dual circuit brake system and handbrake
14 - ASR/ESP Indicator lamp (traction control)*
15 - 16 - Open
17 - Reading coil for immobilizer 2
* Where applicable
18 - Oil level thermal sensor*
19 - Interface - CAN Data Hi-Bus
20 - Interface - CAN Data Lo-Bus
21 - Open
22 - Hood alarm switch*
23 - Multi Function Trip Computer (MFI) - top row (forwards)
24 - MFI - bottom row (backwards)
25 - MFI - memory switch: reset
26 - MFI - ambient temperature display
27 - On Board Diagnostic (OBD) Interface - CAN Data Hi-Bus
27 - On Board Diagnostic (OBD) Interface - CAN Data Lo-Bus
29 - 32 - Open
___________________________________________________________
MK4 Cluster harness BLUE
1 - Terminal 15 - positive (ignition on)
2 - Indicator lamp for turn signal, right
3 - Output signal 1 from electronic speedometer
4 - Open
5 - Fuel gauge
6 - Airbag Malfunction Indicator Lamp (MIL)
7 - Terminal 31 - sensor/sender Ground (GND)
8 - Engine Coolant Temperature (ECT) gauge
9 - Terminal 31 - Ground (GND)
10 - Oil pressure warning lamp................................................
11 - Open
12 - Terminal 61 - warning lamp for Generator (GEN),
13 - 15 - Open
16 - Warning lamp for rear hatch/trunk lid open
17 - Terminal 56a - indicator lamp for high beam headlight
18 - Indicator lamp for turn signal, left
19 - Warning lamp for Anti-lock Brake System (ABS)
20 - Terminal 58b - instrument cluster illumination
21 - Driver's door open warning buzzer 1
22 - Warning lamp for low Engine Coolant Level (ECL)
23 - Terminal 30 - positive (B+)
24 - Terminal 31 - Ground (GND)
25 - Data Link Connector (DLC) K-wire
26 - Parking lights, right (signal for "lights on" warning buzzer)
27 - Parking lights, left, (signal for "lights on" warning buzzer)
28 - Input signal - Speedometer Vehicle Speed Sensor (VSS)
29 - Brake fluid level warning lamp
30 - Terminal 86s - Ignition key warning buzzer
31 - Seat belt warning lamp/buzzer
32 - Open
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 19 May 2013, 21:16 »
Nice one cheers mate, will give this a go on the spare board I've got, saves frying mine lol
