Author Topic: Erm... How do you take the B****y door card off?  (Read 1873 times)
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
« on: 07 August 2005, 18:02 »
My Freind has another problem with her MK3 GTI 2.0 16V.
After just having a new clutch, gearbox and radiator the driver's side window decides that it will pack up and consequently is stuck half-open.
All the other windows and switches work fine.
I need to get inside the Door to have a proper look at the wiring, motor and regulator. How the hell do I go about getting the door card off?   :angry: :angry:
Cheers,
Matt.
WARNING DRUMMER ON THE LOOSE :evil:
Dinky
Re: Erm... How do you take the B****y door card off?
« Reply #1 on: 07 August 2005, 18:21 »
tbh..i thought id wud have just been a case of removin winder,door catch surround(i dont have to remove full thing in mk1 not sure about others),arm rest(where your electric switch is),a couple o screws n mine just pops off...n the door tray-that stoopid plastic bit where you put all ya sweetie wrappers  :laugh: ...that make sense? :laugh:
no doubt one of the boys will come along n give you their version soon... :grin:
Dinx :kiss:
« Last Edit: 07 August 2005, 18:40 by dinx »
mrwotto
« Reply #2 on: 07 August 2005, 18:32 »
Take out the door lock pin, then remove the plastic shroud that the electric window switch is is, this simply pulls off, behind this you will find 2 large phillips hear screws, remove these then its a matter of carefully pully it off
Dinky
« Reply #3 on: 07 August 2005, 18:35 »
opps....forgot the pin...dif between mk1 n mk3 :laugh:
Dinx :kiss:
mrwotto
« Reply #4 on: 07 August 2005, 18:41 »
Dinx :kiss:
Yeah mk3's are superior :grin:
Dinky
« Reply #5 on: 07 August 2005, 18:45 »
all im gonna say is......
:rolleyes:
:grin:
Dinx :kiss:
Silent-Hunter
« Reply #6 on: 09 August 2005, 12:32 »
 :laugh: :laugh: :evil:
