Author Topic: Fit PAS to classic MkII golf GTI ? possible-should I?  (Read 2415 times)
Offline smallzoo
My son has been donated a very earl MkII 1.8 8V Golf Gti from my older brother..lucky him. He is learning to drive in it but he us really struggling with the lack of PAS around the narrow streets where the test is taken..
I have two choices, buy a 'cheap' runaround modern car for him to learn in until he passes his test OR think about fitting a PAS kit to the Golf..
So.. is it possible and is should I ??
Thanks
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Fit PAS to classic MkII golf GTI ? possible-should I?
« Reply #1 on: 18 May 2013, 21:25 »
Hi,
Can be done but it's a big job.
Sub frame has to be dropped to get it in.
For More Info Click To See;
Offline JC
  • Back in the North.
« Reply #2 on: 18 May 2013, 21:27 »
first thing i would do is see if he can actually insure this as his own car once he has passed his test  :lipsrsealed:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 18 May 2013, 21:42 »
This, and also make sure that the tyres are the correct width and inflated correctly, they never were that bad compared to many other cars of that time.
A few extra PSI in the tyres wont hurt either, but no more!
Thom
Offline Craigwilson
« Reply #4 on: 18 May 2013, 21:49 »
Good shout, I have one and I'm 17. Very. Difficult. To. Get. Insurance.
Offline dubber36
« Reply #5 on: 19 May 2013, 08:36 »
They may not have seemed bad at the time Thom, but jeez it feels like hard work now.
jamie16v
« Reply #6 on: 19 May 2013, 11:06 »
if he grows a pair of arms then he shouldnt have a problem.
Offline Mr Blue
« Reply #7 on: 19 May 2013, 21:06 »
Fitting a PAS setup is a piece of cake with axel stands and a jack. Only scary bit on the subframe is the main bolt removal. If it spins you have the cut the floor to weld the captive nut for it to undo.
...and as above. Insurance!
« Last Edit: 19 May 2013, 21:08 by Mr Blue »
Offline weazgti
« Reply #8 on: 19 May 2013, 21:43 »
Knackered bearings in the suspension  top mounts make the steering heavier than wot it should be.
Offline SimonG
« Reply #9 on: 21 May 2013, 08:53 »
Indeed sir! It's much nicer to drive at slower speeds and you still have some good feeling with PAS in a Mk2. Either that or buy him some weights to lift.
  Mk3 Anniversary GTI 16V, Mk2 GTI
