Author Topic: rear discs 97 gti help??  (Read 2914 times)
Offline vwgolf182
« on: 17 May 2013, 16:16 »
need discs for the rear, i got some from a friend but they dont hav the ribbed part on the inside for the abs sensor.
does this come off the old discs or is it part of the disc itself and i need some later model discs??
cheers
Offline Len
Re: rear discs 97 gti help??
« Reply #1 on: 17 May 2013, 16:20 »
You can take the abs ring out of the old and into the new but be careful as it can be fragile.
www.sas.org.uk
www.the-ace.org.uk
Offline vwgolf182
« Reply #2 on: 17 May 2013, 16:25 »
thats great, what would be the best way??
i thought they might but was scared of damaging them
Offline vwgolf182
« Reply #3 on: 17 May 2013, 16:38 »
is ther a discount code i can use for GSF at all??
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 17 May 2013, 16:41 »
nope only ecp...
(you can get a 10% card, but you normally need to buy something/anything first)
Offline Foreveryoungaus16v
« Reply #5 on: 17 May 2013, 16:52 »
You should be able to get the 10% straight away.  This only applies if you buy in store not online I think
:cool:
163 BHP (TSR POWER RUN)
  • Back in a Mk3...
« Reply #6 on: 17 May 2013, 17:19 »
:cool:
it seems to be branch dependant......
I have a tps trade account so gsf are usually more expensive to me!!
VW BUSH
« Reply #7 on: 18 May 2013, 21:42 »
£11 each from ECP
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #8 on: 18 May 2013, 22:51 »
£11 each from ECP
Considerably cheaper than vw  :lipsrsealed: mine are vag ones cost nearly £40 for the pair  :angry:
2000 Mkiv GTi 1.8T AGU
VW BUSH
« Reply #9 on: 19 May 2013, 14:12 »
£11 each from ECP
I think that was with vat as well :grin:
