Author Topic: Window Issue  (Read 3377 times)
Offline sharki786
  • GOT BOOST??
Re: Window Issue
« Reply #10 on: 17 May 2013, 15:07 »
Is it just from the drivers side or does it do the same from the pas door? Could be a broken wire in drivers door as said before
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Shady Pioneer
  • graphic designer.
Re: Window Issue
« Reply #11 on: 17 May 2013, 15:12 »
Just the driver's door mate. I'm going to have a go at the loom this evening so I will soon find out. Not sure how easy or hard it is to replace the whole door loom, but I'll soon find out.  :evil:
Offline madsb
Re: Window Issue
« Reply #12 on: 17 May 2013, 16:13 »
If you think it's a wiring issue why not test the electrical resistance before changing everything?
Offline sharki786
  • GOT BOOST??
Re: Window Issue
« Reply #13 on: 17 May 2013, 17:24 »
Im with madsb
*****MK4 GTI T*****
Offline Leroy
  • Golf GTI Anniversary 16v
Re: Window Issue
« Reply #14 on: 17 May 2013, 19:42 »
My drivers window has just packed up as well dude, fine one day, broke the next, passenger window works off the switch but not drivers and doesn;t make any noise whatsoever.
Going to strip it down and have a look.
Offline Leroy
Re: Window Issue
« Reply #15 on: 18 May 2013, 09:23 »
And ive woken up this morning, drove to work and window now works fine!
VW's are the only cars ive owned that actually fix themselves!!!
