Author Topic: kinked rad hose  (Read 2000 times)
Re: kinked rad hose
« Reply #10 on: 09 August 2005, 14:53 »
Bridge the pins on the temp sender plug, if it still flashes the problem isn't the level sender and is either a wiring or dash cluster problem :)
Offline SimonJ
Re: kinked rad hose
« Reply #11 on: 09 August 2005, 14:57 »
Hi mate, i know this sounds dumb but when u say bridge the pins do u mean put some wire or something in between?
 I did disconnect it completely, and when the ignition was turned on it flashed all the time, would that indicate that it works as well?
Re: kinked rad hose
« Reply #12 on: 09 August 2005, 17:37 »
Yeah a bit o' wire, a paperclip etc between the pins on the plug.
The flashing when unplugged is normal, but wont really help you track down the intermitant flashing problem :)
