Author Topic: Dump valve removal  (Read 3175 times)
Offline Mdwalshy
Dump valve removal
« on: 17 May 2013, 09:00 »
Hi all new to the forum. I have recently bought a mk4 golf gti which has a dump valve I was wondering what original parts I need to remove this.
Many thanks
Mike.
Offline bobbarley
  • I'm kind of a big deal...
Re: Dump valve removal
« Reply #1 on: 17 May 2013, 09:10 »
Morning!  It's actually meant to have a recirculating valve.  Do you know what make has been fitted?  Hopefully it's a Forge which is good, if so, you can safely leave it be.  If it's some chavvy piece of rubbish either pick up a cheap OEM valve from VW, or but a forge 007p and pop that in instead.
Offline Mdwalshy
« Reply #2 on: 17 May 2013, 09:19 »
Morning , thanks for the reply.
It's a baileys , which is annoying every time I change gear :-) I would prefer the recirc valve just so they is no noise on gear change. Once I got the recirc valve would I not need any other parts? There is a blanking plug on a pipe at the back of the engine.
Offline navmk4gti
« Reply #3 on: 17 May 2013, 13:18 »
Welcome..No you dont ..just take blanking plug out and connect recirculating valve in and all pipes. I have a original bosch recirculating valve lying around.
Best bet get a forge 007 or 008 tho :wink: and get silicone pipe for the top vacum pipe on the valve :smiley:
Offline bobbarley
« Reply #4 on: 17 May 2013, 14:40 »
you could pick up an OEM recirc valve for practically nothing, or someone might be nice enough to just let you have one.  It's worth picking up a 007p though if you can, probably don't cost much on eBay these days.
Offline Mdwalshy
« Reply #5 on: 17 May 2013, 14:46 »
Thanks for the advice :-)
I will probably just stick with the OEM one for now, I will get on ebay and see what I can find.
Thanks
Mike.
Offline welshdean
« Reply #6 on: 17 May 2013, 15:06 »
They are being sold on fleabay for ridiculous amounts second hand. If you want a forge one you might aswell buy a new one because people seem to try and sell them for stupid money on there, robbing c**ts . I'm looking for one myself but am not prepared to pay the money they are asking. But then again, I am a tight arse  :whistle:
Offline Mdwalshy
« Reply #7 on: 17 May 2013, 17:25 »
I'm only after a standard OEM one for now might upgrade to a forge one in the future. Can't find any on the bay but will keep looking and hopefully one will come up :-).
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 18 May 2013, 07:50 »
You might need the return pipe that goes back to the metal charge pipe too. Best to get a photo up and we can advise accordingly
Offline Mdwalshy
« Reply #9 on: 18 May 2013, 09:02 »
Thanks for that :-) will grab a picture later and get one posted on here.
