Author Topic: MK4 abs light comes on n off?  (Read 1030 times)
Offline GOLF-MK3-GTI
« on: 16 May 2013, 10:19 »
as above it comes on, then sometimes goes off. then on and then off. I'm going to put it on vagcom to see which sensor is playing up.
i want to know if i replace the sensor, would i need to put it on vagcom and delete it that way, or do i just drive and it'll self check itself and the light will dis-appear. i know its like this on the MK3, But not sure on the MK4?
Thanks
Offline Granta Gti
Re: MK4 abs light comes on n off?
« Reply #1 on: 16 May 2013, 11:15 »
You will have to plug it back in and clear the fault codes.
jamie16v
« Reply #2 on: 16 May 2013, 11:52 »
try cleaning the connection, sensor and also the pick up rings before buying a new sensor.
« Reply #3 on: 16 May 2013, 15:13 »
Thanks Guys.  :cool:
Offline navmk4gti
« Reply #4 on: 17 May 2013, 13:20 »
Most likely its going to be abs speed sensor .. should show on vagcom mine did
Offline Toby
  • Car - less
« Reply #5 on: 18 May 2013, 17:19 »
Try the fuses ontop if the battery
Currently down under
