Author Topic: gear linkage connections (gearbox end)  (Read 1100 times)
jamie16v
« on: 15 May 2013, 21:48 »
anybody know how to remove the little rose joints from the gear shift assembly?. and i don`t mean remove from the cables by twisting and pulling the little plastic foreskin clips back on the springs...  :smiley:
also if anyone has one off the car, could you measure the ball joint for me please.  :wink:
Offline Jin_C
Re: gear linkage connections (gearbox end)
« Reply #1 on: 16 May 2013, 12:43 »
Yank it off. You can use a small spanner as a lever if you need help easing it off.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
jamie16v
« Reply #2 on: 16 May 2013, 13:09 »
i see, i did try that method before and it looked like the rubber was going to break so i left it alone..
i`ll give it another try  :smiley: thanks
Offline AD1.8T
« Reply #3 on: 16 May 2013, 14:25 »
Theres a little metal clip on top of them, flat head to pop them of then just press them back on.
jamie16v
« Reply #4 on: 16 May 2013, 14:26 »
ah, brilliant. thanks for that mate.
