Author Topic: recirc valve pipe.  (Read 1217 times)
Offline scottcamb
recirc valve pipe.
« on: 15 May 2013, 21:04 »
Hope this is ok to post this in here, half way fitting a new recirc valve, and the small vacum pipe that goes to the top has just broke into several peices as badly perished, can i drive my car a few miles without it on, or should i leave the car till i can get a lift to get some new pipe
jamie16v
Re: recirc valve pipe.
« Reply #1 on: 15 May 2013, 21:13 »
if you stay off boost you should be ok.. i wouldnt risk it though.. replace it all the way back to the manifold too.. if you have enough left over do the fuel pressure regulator too!
Offline scottcamb
« Reply #2 on: 15 May 2013, 21:18 »
might suond really stupid, but what do you mean by back to manifold, the black plasticey pipe only seem to got about 20 cms from vavle to the metal pipe
jamie16v
« Reply #3 on: 15 May 2013, 21:36 »
ok, leave metal pipe there and replace black pipe to it. follow metal pipe to other end and replace the pipe thats the other end of it too. i just replaced the lot with once piece.
Offline Nino
« Reply #4 on: 15 May 2013, 21:52 »
Do not drive it without that pipe on u could cause damage to the valve or the turbo. I totally bypassed that metal pope and replaced the whole lot with silicone.
Current - MK6 GTi Edition 35
Offline scottcamb
« Reply #5 on: 15 May 2013, 22:01 »
cheers for the advice, will look into bypass the metal pipe when get a chance, will just get a bit of pipe so can get the car bk on the road
what size pipe do i need?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 15 May 2013, 22:17 »
If you have to drive it block it off and leave the DV nipple with nothing on it and only drive off boost. This is only if you must drive it
jamie16v
« Reply #7 on: 15 May 2013, 22:18 »
4mm.. make sure its proper vac pipe as the clear stuff you get from b&q will just crush under vacuum.
Offline navmk4gti
« Reply #8 on: 16 May 2013, 21:19 »
If you was local could droped u some silicone pipe for it i have sh1t loads  :grin:
As said use propa silicone pipe not crappy see through ones. :wink:
