Author Topic: Fuse Won't Stay In!  (Read 2900 times)
Offline Chris Newman
Fuse Won't Stay In!
« on: 15 May 2013, 19:56 »
Hi Guys,
Just got a 99 Golf GTi Turbo.
Central locking doesn't work, the fob plain does nothing, and turning the key in the doors simply unlocks that door. Checked the fuse box to find that fuse 6 (Central Locking fuse I think), is missing. Put a new 5amp fuse in to realise it wont stay, it just falls back out.
First question, is it likely that fuse 6's absence will be stopping my key fobs working and the central locking working.
Second question, does anyone know of a work around to keep the fuse in place, I've not taken the box out yet to have a look at why it's not staying in (never removed one before so I need to research that)
Last question, how hard is it to replace the fuse box if it can't be fixed?
Thanks in advance guys
99 Golf GTi Turbo - New Project/Learning Curve
Offline DCmk3
Re: Fuse Won't Stay In!
« Reply #1 on: 15 May 2013, 21:39 »
I know it's not ideal but how about putting tape across the top of the fuse and over the surrounding ones so it will remain held in place.
Although if the fuse is falling out, then the actual holder place for that fuse must be bent open which could cause a short circuit if the fuse can lose connection when it moves around on that spot.
As you said Fuse 6, that is the central locking, which will more than likely be needed for the remote to also work.
« Last Edit: 15 May 2013, 21:47 by DCmk3 »
2014 Mk7 GTI - Littco L500
« Reply #2 on: 15 May 2013, 22:16 »
I'll try that tomorrow, cheers mate
Has anyone else ever changed a fuse box, is this a hard task?
« Reply #3 on: 16 May 2013, 12:27 »
Would be be a stupid idea to wrap the fuse pins in aluminium foil to make them thicker so it wedges in place?
Offline DCmk3
« Reply #4 on: 16 May 2013, 12:32 »
I wouldn't even try that to be honest, it could cause some serious issues..
Offline Rhyso
« Reply #5 on: 16 May 2013, 12:33 »
Is it only your central locking that doesn't work?
Try replacing Fuse 14
« Reply #6 on: 16 May 2013, 12:48 »
Seems to only be the central locking, I have also notice when I try lock and unlock it with the key it can sometimes arm the alarm, then I can't disarm it. I basically have to set the alarm off and put the key in the ignition.
The fuel Cap wont stay shut, which I'm hoping is also to do with the central locking. I'll replace 14 and put a fuse in 6 with some tape tonight and let you know how I get on.
Offline Rhyso
« Reply #7 on: 16 May 2013, 16:26 »
DO NOT put a fuse in that position!
If it wasnt there to begin with chances are there was never one. That location might have been used on lesser models
Offline mcgee9t2
« Reply #8 on: 16 May 2013, 17:30 »
yeah dont put a fuse in there. could cause a fire in worst case.
as for the alarm going off, if you unlock car with key you have ten seconds to turn the electrics on before the alarm goes off.
could just be the CCM being uncoded. i know this is why mine does not unlock on the fob but havent got around to coding the ccm in.
« Reply #9 on: 17 May 2013, 12:33 »
Didn't put a fuse in, checked all the other fuses, they were fine, gonna start a new thread for help with the central locking
Thanks for helping anyway
