Author Topic: more problems  (Read 864 times)
Offline daz207
more problems
« on: 15 May 2013, 04:59 »
right i have to prob with my golf  :sad: first thing is my clutch about a month ago i had a prob with it just staying on the floor but after a few pumps it would work again i bled the system a few times and it would be ok for about 2 days then go bk i done this for about 2 weeks so thought i better buy a master cylinder but after buying one it has been working fine till now it has started going to the floor again but only dose it when i drive fast if i just drive slow it will be fine any idears what that could be ?
on the way home tonight the car seemed to struggle as in i boot it and felt like the coil packs where gone again but they where replaced by VW about 2 months ago is there anything else it could be i did have my traction control light stay on the over day and ppl said it is the maf would that make the car run how it did ? once the car gets nice and warm it dose not seem to judder if that helps anyone
Offline Scott-R
  • GoT BoosT!
Re: more problems
« Reply #1 on: 15 May 2013, 06:26 »
Sounds like you need vag-com if the golfs gonna act like this for a while.
Lifesaver of a buy for me for when the vw's feel like playing with our heads ha
Golf GTI ... What else would you have?
Offline luke
  • When in doubt, whip it out!
Re: more problems
« Reply #2 on: 15 May 2013, 07:43 »
Mine was doing similar the other day, felt like it had no power and wouldn't pull, the maf came unplugged, put it back in and ran fine again
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline daz207
Re: more problems
« Reply #3 on: 17 May 2013, 21:34 »
right changed the clutch master cylinder today and it is a little bit better but still dose not come up all the way back up after booting it  :sad: when i was bleeding it the fluid would not go clear there was always bubbles and some times it would even come out looking like foam  :undecided: i really dont no what else to do
Offline D@nCeR
Re: more problems
« Reply #4 on: 18 May 2013, 03:57 »
Are you bleeding it from the slave? Also make sure to keep adding fluid.... When I did mine it took near 1.5litres to get working properly again..
Offline daz207
Re: more problems
« Reply #5 on: 18 May 2013, 05:13 »
Yea doing it from the slave and i used a out a 1L bottle .when i press the clutch pedal down there is a squeak from where the slave cylinder is
