Author Topic: U281 Code Reader ABS  (Read 2894 times)
Offline G5MYT
« on: 14 May 2013, 14:45 »
Hi. New to the forum as I've just bought a Mk3 Gti 16v Anniversary. I have got an abs fault light and was wondering if anybody knew if the U281 reader will tell you which side the fault is on if its a sensor problem? Or will it just tell you about the generic fault? Cheers
Offline G5MYT
Re: U281 Code Reader ABS
« Reply #1 on: 14 May 2013, 15:02 »
Or can anybody recommend a code reader that can tell you the side of the fault.
Offline vwwvgolf
« Reply #2 on: 14 May 2013, 17:42 »
yeah it will give you a code, look the code up on the internet and youl know which one it is. each corner is a different code.
prepare for more than a sensor tho.
Offline vwscottie
« Reply #3 on: 14 May 2013, 17:53 »
You should get a booklet with the code reader with all the codes in
And yes it does tell you which sensor is faulty
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 14 May 2013, 18:13 »
the u281 is a bit basic but I have one for when setting vag-com up takes too long.. it reads and clears codes easy too
Offline G5MYT
« Reply #5 on: 14 May 2013, 20:13 »
That's great thanks. Are there other things I should expect with this fault light?
Offline vwwvgolf
« Reply #6 on: 15 May 2013, 18:14 »
until you scan it, it could be a number of things. could be a big headache. hopefully it will just be a new sensor you need!
VW BUSH
« Reply #7 on: 15 May 2013, 19:33 »
U281 is great, I have one and use it just like ole Boney.
My tip for ABS issues, change all the sensors in one hit.
Not cheap but you will end up chasing dodgy sensors round the car, I reckon they last about 18 months on average :sick:.
When you know they are all good you can focus on the pump if the light stays on.
Even better if you could combine with a brake service :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #8 on: 18 May 2013, 22:55 »
 :lipsrsealed: :grin:
2000 Mkiv GTi 1.8T AGU
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 18 May 2013, 23:10 »
Yep,  mine came with a booklet listing all the fault codes.
