Author Topic: Remote central locking kit recommendations  (Read 3766 times)
Offline willz94
« on: 13 May 2013, 15:44 »
Hello just wondering if any one here has tried any and would recommend ones? Thanks guys
Offline mrsaunders
Re: Remote central locking kit recommendations
« Reply #1 on: 13 May 2013, 15:55 »
i got mine from r click, same as a few other people on here, easy to fit and pretty cheap, fob looks good aswell
http://www.rclick.co.uk/index.php?cPath=50
Offline madsb
« Reply #2 on: 13 May 2013, 20:42 »
Is it possible to fit key and immobilizer chip to that fob, so you don't have to carry around fob and key separate?
Offline spudboy6
  • Just like a golf ......
« Reply #3 on: 13 May 2013, 20:50 »
Above kit I can recommend ! There is a DIY fit guide on here ,
Comes with key blanks so you get them cut to suit your key and then put your iMob chip in it (has a place ) and away you go !
Any help give us a shout , when I got mine to save chopping the loom I got their plug and play kit and just plugged straight in to the pump in the boot
Offline willz94
« Reply #4 on: 13 May 2013, 21:22 »
Would I be able to wire my boot pop into the plug and play they provide?
Offline madsb
« Reply #5 on: 13 May 2013, 21:49 »
..... Has anyone actually succesfully put their key and immobilizer in?
Offline spudboy6
« Reply #6 on: 13 May 2013, 22:50 »
you get the new blank supplied with the kit cut to match YOUR key , and swap the chip from YOUR old key over in to the new one ,
has any one tried it ? , yep ive done my keys , and if you look in the DIY section there is a step by step guide showing the whole process
boot popper i think you can wire up no problem has a button on the fob and spare wires on the control unit , for window closure you need a couple of relays ,
before you ask anymore questions read this
http://www.golfgtiforum.co.uk/index.php?topic=125715.0
« Last Edit: 13 May 2013, 22:53 by spudboy6 »
Offline madsb
« Reply #7 on: 13 May 2013, 23:04 »
Thanks, read it.
Is there a solenoid in the boot already, or will it need to be installed separately ?
Also you speak of relays regarding window closure.. Couldn't find anything about it - isn't it just a matter of wiring up the wires from the key fob control unit to the correct wires to the windows?
Offline willz94
« Reply #8 on: 13 May 2013, 23:10 »
No I have a boot pop wired up to a button and installed a solenoid myself and the I didn't think the windows would need relays as the total closure is already present (turn key to lock while in the door for an extended time and windows will shut)
Offline vr6D4v3
« Reply #9 on: 14 May 2013, 18:58 »
Do a search, there is a how to on here showing how to wire up the relays. Its very easy and doesnt take long, but you do need a relay in order for the total closure to work.
