Author Topic: For all you dieselheads Article on DPF (Diesel Particulate Filter)  (Read 3101 times)
Offline Autobulbs
  • UK's no1. Bulb and Wiperblade Specialist
Hi there everyone I know this is clearly not focused the the GTi owners but some of you have GTD or another commuter car, as you know DPF is a common issue with most diesels. I wrote an article on these the other week for our  blog/help page BHPplus but thought you may find it useful, rather thank linking it I figured it would be better for you re-posting it for you here (even though Google wont like it), I hope it helps at least a bit there was a decent amount of research before I wrote it.
Hopefully it will help  :kiss:
Cheers guys
Particulate Filters (DPF) the thorn in the diesel driver’s side.
Small city commuting car's with the torque and economy of a diesel engine seems like the perfect match and many people have started to realise this. SMMT shows diesel models are accounting for 50% of the overall new car market. The trouble is to meet the strict 2009 Euro 5 emissions guidelines which all car manufacturers must adhere to lowering the harmful gas output from vehicle exhausts.
Among these gasses is Particulate Matter, small molecules of solid or liquid matter suspended in the atmosphere. These can be seen on older diesels as the black foggy cloud of soot that comes from the exhaust under heavy acceleration.
To meet the Euro 5 regulations all new diesel cars are now fitted with a Diesel Particulate Filter (DPF). These filters are a very effective way of removing this particulate matter and can be as much as 85-100% more effective. The DPF filter collects all of the particulate matter, much like a filter would collect dust in your vacuum cleaner. This runs in cycles and when it becomes full needs “emptying”, known as DPF regeneration – this is done by burning off the soot at high temperatures.
There are two forms of regeneration:
Passive, done at constant speed over 50mph
Active, the ECU increases the fuel entering the engine in order to heat up the exhaust gasses
Active regeneration is more common in cars where the filter does not get as hot, cars with a smaller engine or cars that have the filter further from the engine because of space. Some smaller diesel engines also have a fuel additive in a small tank which is added automatically during the regeneration as the engines do not get hot enough.
So how does this affect you?
Not clearing your filter can cause the soot to build up over 75% and after this the filter cannot be cleared via the standard cyclic regeneration. If caught quickly a dealer can induce forced regeneration costing around £200, but as with the fuel additive based engines, this can leave a residue which slowly builds up meaning in these cases the filter has a limited life.
In the long term, if the filter is left too long without clearing, or the residue builds up too much, the filter will need replacing which can cost upward of £1000. Overloading the filter, ignoring warning lights and not seeing a dealer when the error does not clear can completely overload the filter causing excessive back pressure and may lead to irreparably damaging the engine. This could mean paying out even bigger bills in the multiple thousands, to top it off most manufacturers will not cover DPF issues under warranty.
The popular Nissan Qashqai, which has 3 different diesel engines, offers an 18 page thread with 627 replies on DPF issues on the popular Qashqaiclub.co.uk, ranging from members not being told about the DPF when buying the car, to the light coming on signifying a required regeneration after only 3k miles of ownership. In extreme circumstances, taking an extra journey every 2 weeks in order to cycle the filter is the only suitable solution.
But don’t give up hope, this is where you come in!
The first port of call is to refer to your vehicle handbook, as many vehicles will have varying instructions to maximising DPF efficiency and life.
When a filter reaches its pre-set limit, usually around 50%, a light will come on on the dash which indicates the filter should be cleared as soon as possible. To do this generally will involve an un-interrupted 20 minute drive at 40-50mph above 2k rpm; this varies between manufacturers as Nissan ask for above 50mph for 30mins. Because of this, a road where you must slow down for a roundabout will not complete the cycle.
Cars where there is a fuel additive will have a small tank for the additive, very little of this is used and it is topped up during the usual service schedule, this must be completed as without the additive the filter may not be possible to regenerate.
Some cars will suffer from these issues more than others; cars that are used predominantly for town trips will not clear the filter during normal driving. Similarly, small engine diesels which frequently do not get hot enough alongside cars with a very economical top gear keeping the revs extremely low will not reach the right temperature when on the motorway. These may require an extra trip in a lower gear just to clear the filter, whereas some diesel drivers who use the motorway regularly may never see the light or have to clear the filter.
It was a common thought that Tuning boxes used to cause harm to the DPF, the poor tune of some boxes and resistor based tuning boxes did, due to the generic extra load on the endgine would create increased soot and clog up the filter much faster. However the latest Speedhawk boxes do not suffer with the same issue, as they are mapped for the engine specifically, so do not increase soot output as they are optimised. The boxes are actually if anything good for the DPF, especially with smaller engines as the increased boost pressure and performance means the DPF should be easier to clean, which makes the correct cycling temperatures also easier to reach.
There is a wealth of information available on DPF filters at your local forum, but in summary, following your hand book instructions and never ignoring a warning light will save you a lot of money. If you are in the market for a new car and don’t get out on the motorway much, make sure you take into account DPF cycling before you take the plunge.
Offline EsSeX dAn
fairly interesting as it goes i thought!
my next thought was thats why so many of em get deleted
i think i love you.....
Offline Autobulbs
Exactly, I posted a similar thing on a civic forum we are on and there are 2 pages of discussion overnight, appears to be a very hot topic as its costing people a lot when it goes wrong. One had one that cost 1800 to replace! better off removing it and getting the appropriate remap...
Offline EsSeX dAn
1800!? thats ridiculous!
Offline topher
  • Administrator
  • fully functioning
not all of that is accurate/relevant for VAG vehicles but its along the right lines. I do several forced regenerations a week and its astonishing how uneducated the majority of car owners are when it comes to DPF systems.
One other thing worth pointing out is that on some engines, failure of certain engine components (not necessarily exhaust related) can make the ECU block all regenerations, leading to a costly repair if not taken care of quickly... so don't ignore that engine light!
Offline JC
  • Back in the North.
dont buy a vauxhall with a DPF  :lipsrsealed:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Good read  :nerd:
Offline Rhyso
Echo this ^^^^^
I had a customer who ignored his emissions light despite me telling him what the fault was (faulty EGR valve). A couple of weeks later his DPF was dead  :lipsrsealed:
Offline JC
Echo this ^^^^^
He is lucky it was just his dpf -  :whistle:
11 plate insignia off to the breakers - egr snag, dpf blocked, car still driven, bye bye engine.  :shocked:
Gotta love rentals  :evil:
