Author Topic: Will a IBIZA CUPRA 1.8T Engine and turbo fit my GOLF GTI MK4...  (Read 3205 times)
Offline Dommy GTi
  • Dub fiend
Because Im not going to be changing looms over when everything is working fine except for the engine and turbo, also the ibizas standard bhp is 150, which is the same as my golf...
Would it still be a difficult job?  :sad:
You need to check the engine codes are the same
So if i used his ecu id be alright? and by engine codes mine is an AGU T reg 1.8 20v Turbo..
Im not sure on the ibizas, I just know they run of the same engine, but the worst It can do is not work so I guess ill give it a butchers and buy his engine, and if it doesnt run, Ill sell it on i guess.
jamie16v
find out what engine and ecu is in the ibiza then report back.. you`d be better off using the ibiza ecu if it fit`s as it`ll be mapped to suit the engine and turbo.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Ibiza will be AYP
« Last Edit: 18 May 2013, 08:04 by Wazzzer »
