Author Topic: ABF induction kit fitting  (Read 2299 times)
Offline Leroy
  • Golf GTI Anniversary 16v
« on: 11 May 2013, 17:05 »
Anyone provide me with a link for a how to please? Mines fitted but I'm not sure it's right and the instructions are pants!
Offline Screech16v
  • MK3 20vt AGU
Re: ABF induction kit fitting
« Reply #1 on: 11 May 2013, 17:29 »
Hey mate put a pic up and we should be able to see ifs something doesn't look right, I used to run a k/n 57i
Have you done your pump yet?  :smiley:
Offline Leroy
« Reply #2 on: 11 May 2013, 18:26 »
I've pm'ed you screech
Offline Leroy
« Reply #3 on: 11 May 2013, 18:37 »
Just to start me off, Where does the bracket mount on the wing?
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 11 May 2013, 19:11 »
It mounts from the suspension turret mate ,theres a 13mm nut on a stud that you can use,isv pipe goes to the hole at the back of the filter ,there should be a sensor for the air pressure also in the back of the filter,and yes correct about plugging the vac line from the tb,hope this helps.
Offline Leroy
« Reply #5 on: 11 May 2013, 19:18 »
Top man again screech. I've made it look alot harder than it actually is!!!
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 11 May 2013, 19:26 »
Ha ha lol  :grin:
« Reply #7 on: 11 May 2013, 20:43 »
Standard air box is better and will not suffer heat soak.
Offline Foreveryoungaus16v
« Reply #8 on: 11 May 2013, 20:45 »
Yep I ditched mine and went to airbox.  Much better now :cool:
163 BHP (TSR POWER RUN)
Offline Leroy
« Reply #9 on: 12 May 2013, 08:21 »
Just trying it out, picked it up for next to nothing and want to what hear a bit of induction roar! haha! I can always put the original stuff back on if I don't like it.
