Author Topic: 2.0l 8v AGG help  (Read 3944 times)
Offline G mk3 golf
2.0l 8v AGG help
« on: 11 May 2013, 15:19 »
I have 97 1.4 8v mk3 golf and going to be putting a 2.0l 8v in it I have just been told I don't need the loom to go with engine it can be wire in to my 1.4 loom and ecu is this right ? Thanks
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: 2.0l 8v AGG help
« Reply #1 on: 11 May 2013, 15:39 »
It wont work without loom and ecu. I wouldnt reccomend that conversion. You can by 2l 8v pretty cheap nowadays and will allready be equipped with proper breaks and suspensoin.
Offline dom
  • Back in a Mk4
« Reply #2 on: 11 May 2013, 15:45 »
^^^ This.
You'll need the Gti loom/ecu and I really don't see the point in going to all that effort to put an 8v engine in. Why not a 16v/VR6?
Offline Gti_Jamo
« Reply #3 on: 11 May 2013, 16:46 »
I happen to have a full vr6 conversion for sale cheap if you fancy a trip to Scotland lol.
Offline dom
  • Back in a Mk4
« Reply #4 on: 11 May 2013, 17:03 »
How cheap is cheap? I've got a mate after a VR engine...
Offline Gti_Jamo
« Reply #5 on: 11 May 2013, 18:19 »
275 for 95% of the parts needed for conversion Early obd 1 with 145k on it. 140 for engine on its own.
« Reply #6 on: 11 May 2013, 20:42 »
You will need everything from the GTI, pointless conversion when mk3's are so cheap.
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #7 on: 11 May 2013, 21:52 »
yeah man 8vs are so cheap, probably the cheapest gti you can get atm so you may aswell just get a full 8v then you'll have gti spec also. that's unless you're doing the swap for learning/enjoyment purposes. if so then crack on with the conversion and good luck!
Gavv8
« Reply #8 on: 11 May 2013, 22:50 »
8v's win all day long..... :smiley:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #9 on: 11 May 2013, 23:18 »
:afro: i wouldn't mind an abf tho  :grin:
2000 Mkiv GTi 1.8T AGU
