Author Topic: Removing part of seat bracket.  (Read 1334 times)
Offline madsb
« on: 11 May 2013, 10:28 »
Trying to remove the parts of the seat brackets on my leather seats that are broken, so I replace them.. running into a slight issue though, lol.
The part seems to be attached to the rest of the bracket by these clips ... :
Once removed, it looks like this, but I can't seem to figure out how to get it off.. It's just flat..
Any ideas?
Offline swainy
Re: Removing part of seat bracket.
« Reply #1 on: 11 May 2013, 10:30 »
I think they're pretty tight in there, I'm sure last time I did it I got a big flat bladed screw driver to push against it, bit of wiggling and it should come out.
Offline madsb
« Reply #2 on: 11 May 2013, 10:34 »
That's the thing though.. what exactly should come out? And where would you press with the flathead? in between, where the clip used to be? thanks.
Offline Jasikasisback
« Reply #3 on: 11 May 2013, 10:36 »
these the back seats?
Offline madsb
« Reply #4 on: 11 May 2013, 10:49 »
Fronts... but they might be from a passat hahhaa.... the brackets arent exactly the same as on the golf
Offline itavaltalainen
« Reply #5 on: 11 May 2013, 13:34 »
any other clips still holding that bracket on?  :whistle:
otherwise try to wedge a flat screwdriver in and gently try twisting it.... might just break it free. if it does not come off then it's still fixed on somewhere else so don't go mental ;)
Offline madsb
« Reply #6 on: 11 May 2013, 15:55 »
flathead on the end and having a go at it with a hammer did the trick :).
