Author Topic: ABF Inlet manifold Modification question  (Read 2378 times)
Offline ttelracs
  • The Fettler
« on: 10 May 2013, 22:45 »
This has been mentioned a couple of times regarding shortening the runners on the intake manifold.  I recently picked one up on ebay and once I cleaned out all the crud, I matched it to the lower intake manifold and smoothed the inside with a drill and flap wheel.  Once fitted, it was definitely smoother and the mpg has moved slightly.
It's got me thinking though about shortening the manifold runners radically since I now have a spare one to fiddle with.  I was thinking about reducing the length as much as possible and then reattaching the plenum end with silicon pipe and jubilee clips as a temporary solution just to run it and see how if any gains from a purely seat of the pants feel.  I know Ben S on Club GTI has tried, though not as short as I'm proposing and I've seen some American options like this.
http://www.usrallyteam.com/index.php?main_page=product_info&cPath=1_133_3&products_id=291
Before I get the angle grinder out though, can anyone dissuade me from their own experiences or knowledge. I don't want to waste half a day to bolt it on and runs like a dog as I understand the runner length can directly affect torque.
Thanks
Offline tshirt2k
  • Been there...Done that...
Re: ABF Inlet manifold Modification question
« Reply #1 on: 11 May 2013, 10:08 »
Going too short like 1.8T will reduce midrange torque and shifts it further up the range, which isnt good.
Mk3 ABF 16VT Megasquirt V3
Offline ttelracs
  • The Fettler
« Reply #2 on: 11 May 2013, 10:50 »
OK, thanks.
I'll put the angle grinder back then.
Offline tweed
« Reply #3 on: 11 May 2013, 11:25 »
Cut them down so its tight on the plugs.
Offline tshirt2k
« Reply #4 on: 11 May 2013, 11:28 »
Bigger plenum is also beneficial
Offline tweed
« Reply #5 on: 11 May 2013, 11:30 »
Yes, cut 1" off the runners then add 1" to the plenum
Offline ttelracs
  • The Fettler
« Reply #6 on: 11 May 2013, 23:17 »
Like the one Ben S did on Club GTI ?
I could cut down an inch, but would struggle to enlarge the plenum chamber sufficiently.  I'm going to do some research into this and see what I can get..
Offline tshirt2k
« Reply #7 on: 15 May 2013, 12:25 »
Get a decent welding shop to do it.
Offline tweed
« Reply #8 on: 15 May 2013, 17:09 »
My mate works at pro alloy and said its very easy to do. So as said take it to a alloy shop and they'll do it no probs
