Author Topic: Fitting Forge 007p in reverse  (Read 1997 times)
Offline AntMk3GTi
« on: 10 May 2013, 16:04 »
Hi
Is it safe to fit the forge 007p in reverse on a mapped 1.8t AUM (200 bhp)?
Does it still work properly on the green spring?
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fitting Forge 007p in reverse
« Reply #1 on: 10 May 2013, 16:11 »
Why do you want to fit it in reverse mate?
Offline AntMk3GTi
« Reply #2 on: 10 May 2013, 16:14 »
I've heard it could react a bit quicker and apparantly makes a nicer recirc noise?
Just wanted to check it wouldnt do any damage though.
Offline Scott D
« Reply #3 on: 10 May 2013, 16:23 »
doesnt sound too good in reverse and reacts slower IIRC
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline AntMk3GTi
« Reply #4 on: 10 May 2013, 16:54 »
Oh ok. On the Forge website they say it can be fitted either way, but they recommend fitting the same way as the OE part as its much quieter. It doesn't say anything about loss of performance so thought I'd see if anyone had tried this and what their thoughts were.
I'm after a little more recirc noise but dont want an induction kit :smiley:
Offline BarryMKIV
« Reply #5 on: 10 May 2013, 17:55 »
I tried this before out of pure boredom, car was down on power and it sounded like a Glanza. I personally wouldn't bother.
25th Anniversary GTI 1.8T No. 0441
Offline nickellis1
« Reply #6 on: 10 May 2013, 18:02 »
 it wouldn't help , its a pressure loop and designed in a way that the positive boost pressure from the manifold helps to keep the piston closed under boost with the 007 in the correct way . When its reversed it throws  the balance out meaning spring and boost pressure from the manifold struggle to keep the piston closed as the other side of the 007 has boost acting on it from head on type of thing instead of from the sides, resulting in loss of power
Offline Chris.
« Reply #7 on: 11 May 2013, 01:05 »
This!
Click For Build Thread
Offline AntMk3GTi
« Reply #8 on: 12 May 2013, 13:55 »
Ok. On forge's website it says either way is fine?
Will and upgraded panel filter in standard air box amplify the dv sound?
