Author Topic: 280mm brake question (sorry)  (Read 2082 times)
Offline weazgti
« on: 10 May 2013, 11:21 »
So I know I need 16v hubs to run these. I know where I can get the hubs off a seat gti 8v and was wondering whether they have the 280 brakes or is it just abf seats that have these?
Offline gm8
Re: 280mm brake question (sorry)
« Reply #1 on: 10 May 2013, 11:23 »
i had a seat gti 8v that had 256mm brakes, but upgraded to 280s without having to change hub. hope that helps
Offline weazgti
« Reply #2 on: 10 May 2013, 11:42 »
Yeah that's what I needed to know cheers.
So the 256 hubs would be worth having as I all ready have calipers and then is it just discs and pads from a 280mm car?
Offline gm8
« Reply #3 on: 10 May 2013, 11:46 »
yeah thats right , the hubs will take the caliper. just get some 280 discs like you said.
Offline Gambit
« Reply #4 on: 10 May 2013, 19:13 »
You need 280mm carriers also
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 11 May 2013, 01:12 »
This.
Been down Stag Lane then?  :grin:
Early G3 GTIs have 280mm fronts IIRC.  So hubs and calipers off the Seat, carriers off an early G3 GTI.
Check the diameter of the Seat brakes first though - they fitted bigger brakes to some of the later stuff - you *may* get lucky.
Don't forget to replace your master cylinder with a 22mm one, too.
Offline weazgti
« Reply #6 on: 11 May 2013, 02:07 »
Yes stag lane  :wink: I compared them to the golf 3 gti  up there and they looked different that's why I was hoping they d be 280. It was a p reg gti 8v
I got given some 280 calipers from a mk4 diesel with carriers so hopeing they'd fit.
Suppose I could just get the lot and go 256 for a bit. The 239 are pants
  • Opinions я Us
« Reply #7 on: 12 May 2013, 18:22 »
239s are just terrible.
Golf3 changeover year is 1995 going from 280-288mm fronts.  Beavis says so, so it's probably right.
