Author Topic: High miler GTI's are quicker than low miler GTI's  (Read 2677 times)
Offline GOLF-MK3-GTI
watch the video  :smiley:
http://www.youtube.com/watch?v=7sxN5GV8ywY
I know it's a mk2 and a 16 valver, but it'll be the same with a mk3 8 valve won't it?  :smug:
Offline Foreveryoungaus16v
Re: High miler GTI's are quicker than low miler GTI's
« Reply #1 on: 09 May 2013, 18:55 »
Good old top gear days.  Now they just prat about playing car football etc :undecided:
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #2 on: 09 May 2013, 19:10 »
Old Mk3's are a lot lighter than when they were new, so they go faster anyways :grin:
Seriously though, there is a sweet spot (bath tub) where the car has run in and has lower friction so lose less power in the working of the engine and transmission. This is down to service and maint as to how long it lasts and as to when wear is sufficient to reduce output through say compression loss and and reduced drive efficiency.
Classic TG though, Jezza had side show bob hair :grin:
Offline madmanmart
« Reply #3 on: 09 May 2013, 19:21 »
Yep old Top gear was how it should be nowadays.
Mines on 43k so hoping it got more to give yet but I doubt it  :grin:
Yes the arches and sills falling off helps alot  :grin:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline itavaltalainen
« Reply #4 on: 09 May 2013, 19:39 »
my 94 with 2E engine went like the cloppers up till i scrapped it.... and it had 240k miles on the clock.....
was still pulling strong when accelerating at 120mph..... when i lifted off since my winter tyres were rated only 110mph.... and that was a FULLY packed estate (table behind front seat for safety, every last cm3 behind was filled from floor to roof).
VW BUSH
« Reply #5 on: 09 May 2013, 19:48 »
 :grin:
Offline gasketface
« Reply #6 on: 09 May 2013, 20:37 »
Now,if the guy in the white car had remembered to take the handbrake off .................... :grin:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #7 on: 09 May 2013, 21:49 »
Impressed with that shows what looking after the old 8 valve can do :afro:
2000 Mkiv GTi 1.8T AGU
