Golf mk3
hardmonkeys
A True 200HP home built 16v
Topic: A True 200HP home built 16v (Read 3412 times)
tshirt2k
Been there...Done that...
09 May 2013, 14:20 »
Had the pleasure to see this in action an a heartbreaker of a dyno.....
and its on kjet with a blowing manifold.
More to come with ITBS and EFI. Imagine getting left by this tatty old cab.
http://www.youtube.com/watch?v=7edkPLvtoI8&feature=player_embedded
Mk3 ABF 16V
T
Megasquirt V3
VW BUSH
Guest
Re: A True 200HP home built 16v
09 May 2013, 19:13 »
Great Stuff
tshirt2k
09 May 2013, 19:17 »
Forgot to add it a home ported head with mildish cams 276/268 IIRC. And obviously a 2.1
Mk3 ABF 16V
T
Megasquirt V3
VW BUSH
Guest
09 May 2013, 19:50 »
Quote from: tshirt2k on 09 May 2013, 19:17
KR top end i take it?
tshirt2k
09 May 2013, 19:53 »
I wouldn't have thought so. I think it's probably an ABF.
Mk3 ABF 16V
T
Megasquirt V3
xionsolaris
Here all the time
09 May 2013, 21:15 »
It must be a abf bottom end bored with a mk2 head with mechanical injection
tshirt2k
Reply #6 on:
09 May 2013, 21:49 »
You can fit kjet to an ABF to a complete ABF engine.
Mk3 ABF 16V
T
Megasquirt V3
xionsolaris
Here all the time
Reply #7 on:
10 May 2013, 06:33 »
Is there any reason why anyone would do that u would think electronic injection woupd be miles better than kjet
tshirt2k
Reply #8 on:
10 May 2013, 08:03 »
It is, but its a crude way if getting it to run. And it will run well enough.
If you have a kjet car, you can swap over the bits to the ABF block to get you running without extra wiring.
Mk3 ABF 16V
T
Megasquirt V3
stainesy
im not a master debater but i'm a cunning linguist
Reply #9 on:
10 May 2013, 08:11 »
Am I in the wrong section?
Could have sworn that wasn't a mk3
Golf mk3
hardmonkeys
