Author Topic: Mk4 1.8t 20v AGU. Head is it more then the gasket  (Read 2594 times)
Offline Bensuv87
I brought the car knowing the head gasket had gone. There's oil in the water is this more then the gasket and the actual head it's self ??
Are there any quick fixes??? I've looked at replacement engines. Mines got the ko4 turbo and a remapped ecu. Would these jst b able to b moved over to the engine with ease.
Also mines an agu would the other engines work with my wiring loom???
Offline danny_p
Re: Mk4 1.8t 20v AGU. Head is it more then the gasket
« Reply #1 on: 10 May 2013, 00:17 »
oil in water usally the oil cooler not the haed gasket
all the VW's have gone bar 1.
Offline Bensuv87
« Reply #2 on: 10 May 2013, 11:11 »
When I picked the car up there was a patch of oil on the floor beneath the car. Does this help your diagnosis
Offline Bensuv87
« Reply #3 on: 10 May 2013, 16:40 »
I just moved the car to get into garage. After revearseing back there was dropping water with lots of oil in it. But it was mainly water.
Offline danny_p
« Reply #4 on: 10 May 2013, 18:33 »
if oil cooler fails,  engine oil system is at higher pressure than the coolant system so oil will be pumped into the coolant system.
this can cause the coolant system to overflow so it may leack oil and water from the top tank.   usual sings are engine oil dropping and oil in coolant.
it's not allways the case but a lot of people see oil in water and shout head gasket even garages.   i've bought loads of 20Vt cars for peanuts as owner belives the head gasket has failed or they've had teh head gasket done and it's still doing it so presume dead motor.
£15 second hand oil cooler ,   empty to cooling system fill it up with plain water and some washing powder ir a couple of dishwasher tablets and take it for good drive.   supriseing how meany of them it cures,     then dump the "coolant"  run it for a day or two on water then drain and fill with g12
Offline Bensuv87
« Reply #5 on: 10 May 2013, 19:56 »
Firstly THANK YOU!!!!!!!! You r a legend!!! Is this an easy job to do could i do it my self??? Or garage???
Offline danny_p
« Reply #6 on: 10 May 2013, 21:15 »
if you've got a few tools you'd be abel to DIY it quite easy.
diconnect water pipes from oil cooler,   remove oil filter, remove nut oil cooler falls off.
not 100% garanteed it's that but unless it's had a new one allready it's due to fail at some point soon ish,
if you wish to test it,  disconnect the water pipes going to the oil cooler  and link them together,  then run the engine,  or even take it for a short drive,    if the oil cooler is at fault you'll see oil comeing out the water side of it
Offline Bensuv87
« Reply #7 on: 10 May 2013, 22:23 »
Well I've got a Mecanic coming to door soon. So I will keep u posted.
Cheers again Ben.
