Author Topic: silicone hose - EVAP to TIP  (Read 890 times)
Offline Scott D
« on: 08 May 2013, 23:52 »
I need to replace a pipe running from the EVAP hardline to TIP but can't get fuel hoses until Monday.
Would a regular silicone/vaccum hose handle fuel vapour as a quick fix for a few days?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline paultownsend
Re: silicone hose - EVAP to TIP
« Reply #1 on: 09 May 2013, 07:50 »
You mean to the charcoal canister?
If so just rip it all out my friend and plug the tip end and the TB end.
Offline Scott D
« Reply #2 on: 09 May 2013, 18:00 »
thats next on the to do list  :grin:
got fixed up with correct hose thank f**k
