Author Topic: Is it possible...  (Read 1603 times)
Offline Brads MK2 GTI
Is it possible...
« on: 08 May 2013, 14:08 »
For an incorrectly or badly fitted / sealed rocker cover gasket to cause a vacuum leak, leading to rough slightly hunting idle, stalling at junctions and exhaust popping / back firing under braking?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Is it possible...
« Reply #1 on: 08 May 2013, 15:45 »
At a guess - yes...
If the rocker cover oil breather gasket is split and it causes the same issues - So I've read somewhere.. :D
For More Info Click To See;
Offline xionsolaris
« Reply #2 on: 08 May 2013, 21:39 »
Can u see oil leaking out a bad gasket seat will always show some signs of oil leaking as there is a slight gap that oil can escape from
