Author Topic: how far should the front strut sit in the hub  (Read 786 times)
Offline wolfie1981
« on: 07 May 2013, 19:50 »
as above fitted my front fk's today just wanted to know how far should the strut sit in the lower hub???
I have mine sitting flush with the bottom of the hole / hub is this correct or doe's it need pushing in more???
Offline Hoggy
  • Mk4 GT TDI 150.
Re: how far should the front strut sit in the hub
« Reply #1 on: 07 May 2013, 20:09 »
It must be right or the bolt wouldn't go through the hole in the loop on the strut. ;)
Offline mcgee9t2
« Reply #2 on: 07 May 2013, 20:16 »
if the pinch bolt goes through the tab then its in properly.
if its not in then put the front up on axle stands, jack under the wishbone, jack it up a little so theres pressure under the wishbone, then get a big screw driver/crowbar or something that you can lever the strut mount open with. (makes it a little easer to go in if you lube it up with copper slip or something)
