Author Topic: Coolant leak  (Read 2474 times)
Offline hardmonkeys
Coolant leak
« on: 07 May 2013, 16:55 »
I'm gonna tackle this coolant leak I have...it's sometimes REALLY bad..where it does nothing but piss out...then sometimes it does nothing..
Moved it off my drive to swap cars over on Sunday, literally 30 secs of movement...pissing out.
Today I drove it 60 miles to work and back...nothing! Not a drip..
Anyone on here had this problem, is it a common one? What did you do to fix?
I bought some radweld...but not sure if I should be using it, heard some bad things about it blocking all the little airways in the block.
I've tried looking under the car,
This was after the 30 secs of moving about, not exactly sure if its coming from the top of the engine...or bottom..was thinking of stripping the front down to have a better look..
Any help advice is appreciated
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline brewey
Re: Coolant leak
« Reply #1 on: 07 May 2013, 17:30 »
I would take the front off and see if you can locate it. Radweld could cause more harm than good! Plus if you find it you know you can fix it properly, it might be something simple you can never tell
2000 1.8T ARZ - OEM+
Offline brewey
Re: Coolant leak
« Reply #2 on: 07 May 2013, 17:31 »
Forgot to say the front is easy to remove 15mins tops if it your first time but I can't see you having any problems with that part of the task.
Offline hardmonkeys
Re: Coolant leak
« Reply #3 on: 07 May 2013, 17:40 »
That simple??? Wow! Expected longer than that lol
Will have ago at the weekend
Offline navmk4gti
Re: Coolant leak
« Reply #4 on: 07 May 2013, 18:01 »
Yup as said take front bumper off. Very easy on mk4 just dont drop it  :grin: try having look from top engine too for any coolant puddles or marks in the engine bay on any pipework that normally is easy give away too
Offline hardmonkeys
Re: Coolant leak
« Reply #5 on: 07 May 2013, 18:25 »
Aye, I thought id seen it dripping from the top...not entirely sure tho! It's coming off the road at end of month anyway, tax is up, will get as much done before I retax at end of August. Looking forward to it
Offline Dalo Harkin
Re: Coolant leak
« Reply #6 on: 08 May 2013, 09:42 »
looks similar to mine, I have a very slight leak from down the timing chain cover, have you overfilled the coolant bottle as it does have an overflow that if you overfill it obviously it will leak out the overflow.
Offline matty james
Re: Coolant leak
« Reply #7 on: 08 May 2013, 13:27 »
looks like a leaking water pump to  me, its exactly where i was getting a leak a couple of weeks ago . was hard to tell where it was coming from until we put it on the lift.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline hardmonkeys
Re: Coolant leak
« Reply #8 on: 08 May 2013, 14:03 »
It was fine when I got it, 2mths back now, then I remembered I changed the thermostat and coolant temp sensor, doesn't seem to be leaking where the 'stat is...could be a coincidence...it's annoying coz it sometimes doesn't leak, then another time it doesn't stop lol
Offline mar_k
Re: Coolant leak
« Reply #9 on: 08 May 2013, 16:56 »
Bet its the bottom corner of the rad, Mine went the same place.
Got a rad off carparts4less for £30. easy to fit aswell.
take a look at the corner of the rad with a torch. if its leaking you will see dry pink crystal parts where the coolant has dried.
