Author Topic: Occasionally hesitant  (Read 1104 times)
Offline vala
« on: 07 May 2013, 13:03 »
Since owning my Golf it has been spot on in terms of its running performance however most recently on occasion the car starts to become very hesitant when applying power. This seems to clear once I clear it's throat and then normal operation is resumed.
Anyone know what could be the cause here?
Car is due it's 80,000mile service soon so I'm gathering up all the bits to complete that shortly.
Offline nottyash
Re: Occasionally hesitant
« Reply #1 on: 12 May 2013, 14:31 »
Ive had a similar problem.
It turned out to be a coil pack.
2002 51 Golf GTI 1.8T Black
2002 02 Golf GTI 1.8T Blue
2003 53 Ford Mondeo ST 220 Estate Blue
2004 54 Mini Cooper S
Offline vala
« Reply #2 on: 12 May 2013, 17:03 »
is there anything that can be done to test the coil pack?
Offline navmk4gti
« Reply #3 on: 12 May 2013, 18:10 »
Get on vagcom and scan for fault codes first
Offline nottyash
« Reply #4 on: 12 May 2013, 20:52 »
They don't always show up as a fault code. Just a bit spluttery and hesitant.
I remapped mine and the fault came up as it started running even worse. It came up as cylinder 2 misfire.
The cheapo OBD reader on ebay for a tenner may do the trick. It worked on mine.
It happened again a few days later so I changed all 4.
So far so good. :smiley:
