Author Topic: confused at cd player fault  (Read 1589 times)
Offline davemk4
« on: 06 May 2013, 17:11 »
Right got a 2001.... bod standardsingle cd player with tape deck control at bottom never had an issue untill burnt a cd popped it in and came up with magazine error ......so re did disk. Did same again. Thought ok is it cos it in mp3 format i converted it and did again didnt work. Thinking cd player packed up tried my old copy cd in works as should.  Tried new cd no luck. But then while at my dads today he owns a 52 plate gtdi his same cd player set up abd his works all cds fine but what i noticed was his tapedeck was slighly dufferent it doesnt have removrable bottom buttons with safe behind it like mine. Never knew there was different kits. Any ideas on this....faulty or am i missing summit here :sad:
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline tallpaulr
Re: confused at cd player fault
« Reply #1 on: 06 May 2013, 18:18 »
It could be how the disc was burnt. Ive tried a couple on my new laptop and they didnt work in the car but tried some id done on my pc and they worked fine.
Offline davemk4
« Reply #2 on: 06 May 2013, 18:40 »
i thought this but why would they work all ok on my dads mk4? slightly different model head unit but still oem
Offline tallpaulr
« Reply #3 on: 06 May 2013, 18:44 »
It could be the laser reader in the unit is different. I know some that ive burnt will play in our stereo downstairs but then not in my sons in his room.
Offline davemk4
« Reply #4 on: 06 May 2013, 18:46 »
hmmmmmmmmm just really odd my other copied and original disks all work ok
Offline tallpaulr
« Reply #5 on: 06 May 2013, 19:04 »
Have you burnt them the same way? Are they on the same discs?
Offline davemk4
« Reply #6 on: 06 May 2013, 19:30 »
They on same make of disk branded too. Done in mp3 amd wma same as over disks whixh work. Might try a different disk brand
Offline tallpaulr
« Reply #7 on: 06 May 2013, 19:40 »
I don't think it'll hurt
Offline davemk4
« Reply #8 on: 11 May 2013, 16:55 »
Still playing up used nero slower speed different make of cd. But still no issue on parents mk4 and other copied disks work fine
Offline Rhyso
« Reply #9 on: 11 May 2013, 17:30 »
MK4 stereos could never play MP3's  :huh:
