Golf mk3
hardmonkeys
the black vacuum line-where can i get decent replacement
Topic: the black vacuum line-where can i get decent replacement (Read 1469 times)
Jasikasisback
03 May 2013, 21:53 »
these are the two black braided 3mm vacuum lines near the air intake plastic bedpan shaped air intake above the throttlebody. i bought some on ebay but they tend to collapse and starve the engine of air. are they available anywhere? my silicone ones are not a goid replacement.
Last Edit: 03 May 2013, 21:58 by Jasikasisback
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: the black vacuum line-where can i get decent replacement
03 May 2013, 22:28 »
http://stores.ebay.co.uk/venairperformancesiliconehoses
I bought some 3mm silicone tubing on eBay from these guys about a year ago and it's been absolutely fine.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
04 May 2013, 09:44 »
I used marine grade fuel line with ID 3mm for vacuum hoses on my engine. Works brilliant - they are braided on the outside as well as fairly thick (OD is a lot larger than original vacuum hose) so don't collapse easily.
Jasikasisback
05 May 2013, 10:23 »
where can i buy stuff like that?
itavaltalainen
05 May 2013, 12:50 »
egay
http://www.ebay.co.uk/sch/i.html?_odkw=petrol+hose+3mm+id&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=braided+petrol+hose+3mm+id&_sacat=0
VW BUSH
Guest
05 May 2013, 15:32 »
OEM £3 pm at VW, or completely free if you raid the automation dept at work
Golf mk3
hardmonkeys
