Author Topic: Engine swap help  (Read 2739 times)
Offline G mk3 golf
Engine swap help
« on: 03 May 2013, 21:17 »
Hello poeple. I have a 1997 mk3 1.4 I am going to be doing a 2l 8v engine swap i just got 2l mk3 golf cheap and going to swap everything in to my 1.4 What bits will I need to change engine gearbox driver shifts loom ecu ? Do I need to change the dashboard loom ?
Offline xionsolaris
Re: Engine swap help
« Reply #1 on: 03 May 2013, 21:53 »
U need the wiring loom ecu and a coded key to that ecu the drive shafts are probarly the same the wiring loom will plug into the fuse box so no major wiring mess
« Last Edit: 03 May 2013, 21:56 by xionsolaris »
« Reply #2 on: 03 May 2013, 22:03 »
If you have got the complete car, I would swap everything over including the brakes and 5 stud wheels etc, very little on the 2.0 is shared with the 1.4.
Don't forget to tell the DVLA and your insurance company when you have finished
« Last Edit: 03 May 2013, 22:05 by Wayne »
Offline G mk3 golf
« Reply #3 on: 03 May 2013, 22:07 »
So it's not big job ? I have the key that go with the ecu. Will change everything I just want to get the engine side of things done 1st so I know that's done
Offline xionsolaris
« Reply #4 on: 03 May 2013, 22:13 »
Its not major as these engines were made for a mk3 golf but one thing if you got abs u can say goodbye to it change engine ecu the ecu will talk to the abs pump and it will be a different part no ecu if youve got a donar car no biggy and if the abs ecu number is the same as the 2.0l abs ecu thts oki
Offline G mk3 golf
« Reply #5 on: 03 May 2013, 22:22 »
My 1.4 don't have abs ? If I was to have week off work could this be done in week ? Or am I living in dream world lol
Offline G mk3 golf
« Reply #6 on: 03 May 2013, 22:36 »
My car as Clifford alarm will that matter ?
« Reply #7 on: 03 May 2013, 23:42 »
You will need to get that rewired after the conversion.
Offline G mk3 golf
« Reply #8 on: 03 May 2013, 23:48 »
Ok thanks. The engine I will be putting in is a AGG will I need to get key recode to ecu ?
« Reply #9 on: 03 May 2013, 23:52 »
You will need all the parts from the GTI including the key, ecu and transponder ring.
