Author Topic: Newbie needs some help......  (Read 943 times)
Offline jhunter_83
« on: 03 May 2013, 20:47 »
Hello,
Just swapped from standard headunit to a RCD510 that I bought from ebay.
The system switches on when you turn the key to position 1, but when you start the engine the system goes off.
It will go on when you switch it on at the unit but switches itself off after a while. it also wont switch off when you take the keys out of the ignition.
Do I need to do something for it to work or is it a faulty unit?
I have read about ignition switches but the fact that it switches on when turning the key to position 1 makes me think that isn't the problem.
It is in a mk6 GTI.
Thanks
2010 Silver Golf GTi 5 Door, Poverty spec wheels, RCD510 Bluetooth and DAB, Pagid Discs and Tarox Strada Pads
Offline Murrayedition35
Re: Newbie needs some help......
« Reply #1 on: 05 May 2013, 19:40 »
Hi there and welcome.. :smiley:
