Author Topic: MBE 992 ECU Repair?!  (Read 3030 times)
Offline awallis
« on: 03 May 2013, 19:15 »
Ive got a misfire and my 4th injector isn't spraying, checked all the components + wiring, no fault found. so suspect ecu.
Wonder where can I get it repaired?
Thanks.
Offline Toby
  • Car - less
Re: MBE 992 ECU Repair?!
« Reply #1 on: 16 May 2013, 19:59 »
Is it a agu?
Have you tried a ignition amplifier?
Currently down under
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #2 on: 20 May 2013, 12:31 »
ECU repairs - POWERTUNE Widnes - 0151 423 5295  :wink:
Offline Ben@VWH
« Reply #3 on: 27 August 2013, 14:15 »
Thread bump. If you haven't yet fixed this issue, i'd suggest it isnt the ecu at fault, as the mbe fires the injectors semi sequentially (1&4 together and 2&3 together). So if only 1 injector isn't working, a wiring fault or faulty injector is more likely.
