Author Topic: cuting out issues!!  (Read 1657 times)
Offline dannyxr2i
cuting out issues!!
« on: 02 May 2013, 21:47 »
hi all..
iam now stuck and ran out of ideas with the mk2 golf.
got the gti 16v kr engine,
problem is, start the car up runs fine for about 1 and then just cuts out,, fuel pump primes and buzzes, had a new 1 15 20k ago, car has just had new coil, temp senors as been told these could of been the problem, but now iam thinking fueling,
could it be lift pump?? injectors etc.
any help would be greatfull, if not its off to the garage, where no doubt will be looking at a big billll lol..
Offline zebedee
  • 1990 GTi8v
Re: cuting out issues!!
« Reply #1 on: 02 May 2013, 22:09 »
Easy geezer.
Not a mechanic but have had similar issues on my 8v. Turned out it was the main oil sensor causing the buzzing and the cutting was due to a goosed sensor under the dizzy cap. Have you tried replacing the dizzy cap or ht leads?
Offline eggs
« Reply #2 on: 04 May 2013, 01:16 »
i had that problem on my 16v some time after i bought it. only seemed to happen when it was cold or wet.
i asked the garage if the dizzy cap and ht leads needed replacing. they had a look and found a small crack in the rotor arm which was causing it to short circuit.
replaced everything and had no problems since.
just copied/pasted this as it explains it better than i can...
If there is a spark at the points, check the rotor arm. This is perhaps the most common cause of the engine suddenly going dead. A hairline crack in the rotor arm will gather dirt and allow a short circuit to its spindle. Even new rotor arms die occasionally! A simple diagnosis for rotor arm failure is that there will be a spark from the HT lead from the coil to the cap, but no spark at the spark plug leads. (Though this would also be the case if the distributor cap cracks around the centre HT socket)
« Last Edit: 04 May 2013, 01:19 by eggs »
