Author Topic: Bolts  (Read 2211 times)
Offline bulk66
  • Im broke an it aint a joke!!!!
Bolts
« on: 02 May 2013, 21:36 »
Hi all am I right in saying to remove the rear boot lock on my mk2 that I have to take the off the trim that surrounds the lock (covers the number plate bulbs ) if this is right then is there any were I can buy new bolts and the plastic clips because the 4 bolts have rusted and rounded off  :whistle:
Offline Thom89
  • Looking for an "Icebreaker"
Re: Bolts
« Reply #1 on: 03 May 2013, 01:20 »
Yes, you have to remove the tailgate plinth, as it traps the lock in position, the lock should have a thin piece of foam gasket that traps against the tailgate, this stops it rattling when you shut the tailgate, and cuts down on water entering the tailgate, just use a plasticine type sealer to replace the gasket if it disintegrates
The screws and clips are available from the Dealer, or VW Heritage, you may have a problem with the square holes that the clips fit into corroding! if this is the case, you may need to use another type of fixing!
Thom
« Last Edit: 03 May 2013, 02:02 by Thom89 »
Offline bulk66
Re: Bolts
« Reply #2 on: 03 May 2013, 07:25 »
Cheers dude nice reply  :smiley: dealers here I come.........
Offline bulk66
Re: Bolts
« Reply #3 on: 03 May 2013, 09:33 »
Just spoke to Newbolds in Mansfield they saying part is no longer available  :cry:
Offline bulk66
Re: Bolts
« Reply #4 on: 03 May 2013, 09:37 »
Can't see any on vw heritage....... Any more ideas any one????
Offline Thom89
Re: Bolts
« Reply #5 on: 03 May 2013, 22:56 »
These are the boys...
http://www.vwheritage.com/vw_spares_Expanding-Nut-Tailgate-Handle-to-Body-Golf-Mk2-4-req-1H6827584A_act_shop.product_pID_140710409_lang_EN_country_GB.htm?crumbStartPage=2&crumbStartRow=18
Screws or bolts, most mk2s had plated large Phillips screws, but some later cars had 8mm black plated spire self tapping bolts, either should be available from a fixings stockist
Thom
Offline bulk66
Re: Bolts
« Reply #6 on: 04 May 2013, 15:04 »
Right cheers mate  :smiley:
