Author Topic: Gti 8v still won't start :( HELP  (Read 2832 times)
Offline arran.concept
  • Yellow Colour Concept
« on: 01 May 2013, 22:22 »
Recently changed crank shaft sensor, still not fixed the problem, car won't start :( any suggestions please
Offline GOLF-MK3-GTI
Re: Gti 8v still won't start :( HELP
« Reply #1 on: 01 May 2013, 23:15 »
Need more info,
when won't it start, hot or cold?
Any lights flash on dash, such as oil light. Does it cut out or anything?
Have you had it on vag-com? And how come you changed crank sensor?
Need to be more specific?
« Reply #2 on: 02 May 2013, 19:05 »
Won't start at all, and the cars putting out no readings.
Few local mechanics thought it could be the crank sensor.
Everything's normal with clocks ect just isn't firing up :( fuel pumps fine ect just doesn't seem to start mate.
Offline DCmk3
« Reply #3 on: 02 May 2013, 19:08 »
Is it sparking?
2014 Mk7 GTI - Littco L500
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 02 May 2013, 20:05 »
Is it sparking?
Thats what i would do. If your getting petrol into the engine then check the spark. An old sprak plug on the 1st (drivers side) lead and lean it against the engine if coil pack is good you will see a small spark if not then coil pack is fooked. But make sure you get a good earth by touching the engine side
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #5 on: 03 May 2013, 09:43 »
Have you changed coil recently? I think its your coil.
« Reply #6 on: 03 May 2013, 16:14 »
I will go try this now, can you explain a bit very what to do :)? Cheers mate
« Reply #7 on: 03 May 2013, 16:20 »
well firstly you will need another ignition coil, borrow one to try out or buy a new one. It's located under bulkhead, near coolant bottle.
Was your car driving fine before it refused to start?, if so I'm defo sure it's coil.
« Reply #8 on: 03 May 2013, 16:51 »
Yeh mate drove 6miles parked the car and went to McDonalds and came out an the car just wouldn't fire up
« Reply #9 on: 03 May 2013, 16:56 »
60**miles, the starter goes and goes but just doesn't fire up :(
