Author Topic: 16v Overheating  (Read 1559 times)
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
16v Overheating
« on: 05 August 2005, 00:09 »
MY MK2 16V JETTA IS FINE ON A RUN BUT AS SOON AS IN TRAFFIC THE TEMP GAUGE INCREASES INSTANTLY. THE FAN WORKS OKAY AND IS COOL ON A RUN. WHAT COULD MY PROBLEM BE?
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
Re: 16v Overheating
« Reply #1 on: 05 August 2005, 00:22 »
Not really an issue unless the gauge goes through the roof!  :shocked:
As a suggestuion though, try flushing the rad, engine and heater matrix and refilling with a 50/50 mix of antifreeze and water.
When I changed the head gasket in my engine I ran the car on plain water for about a month, the temperature fluctuations were quite drastic but nothing to worry about.
As soon as I put antifreeze in (after flushing the engine etc..) the guage now happily sits in the middle of the range and only really decreases to about 1/4 when driving down the motorway.
WARNING DRUMMER ON THE LOOSE :evil:
Offline jettaTx
Re: 16v Overheating
« Reply #2 on: 05 August 2005, 10:22 »
Good idea i will check the coolant level in the resevior on dinner.
Offline Redbaron
Re: 16v Overheating
« Reply #3 on: 05 August 2005, 19:21 »
thats normal mate.
16v has the smallest radiator out of the golfs.
figure  :shocked:
Re: 16v Overheating
« Reply #4 on: 08 August 2005, 11:39 »
It is the same physical size as the 1.6 Driver radiator, but is double cored so more efficient than an 8v rad ;)
Offline Neaty
Re: 16v Overheating
« Reply #5 on: 15 August 2005, 15:48 »
my valver used to do the same the gage would go to 2 3rds of the way up and the oil temp would be about 105 degrees wich concerned me at first but it never really got out of hand! i would agree with the 50/50 water anti-freeze idea
