Author Topic: Braking Judder  (Read 1788 times)
Offline stfc_gti
Braking Judder
« on: 29 April 2013, 09:45 »
So I took the golf out for the first time in about 2 months, its recently had a new battery and fuses.
It would now seem when I brake the car has developed a judder through the steering wheel
The judder is worse the harder I brake. If its a slow gentle break, there is no judder at all.
Any help would be great
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Ashmond
  • Money, b!tches And Boost
Re: Braking Judder
« Reply #1 on: 29 April 2013, 10:07 »
Warped discs, loose driveshaft nut, wheel bolts
Offline Granta Gti
Re: Braking Judder
« Reply #2 on: 29 April 2013, 10:17 »
I would say warped discs.
Re: Braking Judder
« Reply #3 on: 29 April 2013, 11:04 »
Warped disc or sticking caliper
Offline Dalo Harkin
Re: Braking Judder
« Reply #4 on: 29 April 2013, 12:54 »
+1 on warped disc/s
Offline stfc_gti
Re: Braking Judder
« Reply #5 on: 29 April 2013, 13:02 »
thanks for the replies, how do I diagnose warped discs? should I be able to see something on them?
Offline Dalo Harkin
Re: Braking Judder
« Reply #6 on: 29 April 2013, 13:07 »
No, they only need to be marginally warped to get a wobble
Offline Granta Gti
Re: Braking Judder
« Reply #7 on: 29 April 2013, 14:12 »
You could use a dial test gauge see if they are warped
Offline stfc_gti
Re: Braking Judder
« Reply #8 on: 29 April 2013, 15:16 »
is it just a case of replacing the discs/pads?
Offline Ashmond
Re: Braking Judder
« Reply #9 on: 29 April 2013, 17:17 »
yep
